DTC P0720: LOW OUTPUT SPEED SENSOR RPM ABOVE 15 MPH Circuit Description Circuit is monitored continuously while ignition is on and gearshift lever is not in Park or Neutral. DTC sets if vehicle speed is above 15 MPH and output shaft speed is less than 60 RPM for 2.6 seconds as measured from vehicle speed signal. Possible Cause Open output speed sensor ground circuit.&#
