DTC P0743: TORQUE CONVERTER CLUTCH SOLENOID/TRANS RELAY CIRCUITS
Circuit Description
Circuit is monitored continuously while ignition is on. DTC sets if voltage detected on TCC at PCM does not match desired voltage.
Possible Cause
The following items may be area of concern:
Fused B+ feed to transmission control circuit open.
