DTC P1291: NO TEMPERATURE RISE SEEN FROM INTAKE AIR HEATERS Monitor & Set Conditions Temperature rise from intake air heaters is monitored for first 15 seconds of engine operation. DTC may be stored if initial Intake Air Temperature (IAT) sensor reading is 0-66°F (-17.8 to 18.8°C), Battery Temperature Sensor (BTS) and IAT sensor are within 10°F of each other, time between end of preheat and engine run state is less than 3
