DTC P1899: P/N PERFORMANCE Monitor & Set Conditions Park/Neutral (P/N) switch is monitored continuously with transmission in Park, Neutral or Drive and not in limp-in mode. DTC may be stored if PCM detects an incorrect P/N switch state for an given mode of operation. Possible Causes Intermittent Transmission Range Switch (TRS) Sense Circuit
