LED Lighting - Courtesy Lighting Parts listing LED map light bulbs LED dome light bulb   Dome light bulb install you need to carefully pry the driverside of the dome light lens downward. It will hinge on the passenger side. Simply pull the bulb and install the new bulb. If it doesn't light up turn it around 180 degrees and install again.   Map lights you need to open the garage door panel. Inside there are two tabs and push to the opposite side and caref
