P0720 OUTPUT SPEED SENSOR ERROR When Monitored and Set Condition: When Monitored: The transmission gear ratio is monitored continuously while the transmission is in gear. Set Condition: If there is an excessive change in output RPM in any gear. This DTC can take up to five minutes of problem identification before illuminating the MIL. POSSIBLE CAUSES OUTPUT SPE
