P0087 - Fuel Rail Pressure Too Low
Special Tools: Click to display a list of tools used in this procedure
When Monitored and Set Conditions
When Monitored: This diagnostic runs continuously when the following conditions are met:
• With the engine running.
Set Conditions:
• The Powertrain Control Module (PCM) detects that the actual fuel pressure reading is below a calibrated threshold. This DTC will cause active regeneration to be disabled.
Default Actions:
• The
