For Sale - 2006 Dodge Ram 2500- Flatbed for long box bed Winch bumper Flat Bed for Long Box 3rd generation Cummins Tootlbox are included with key I have a flatbed for 3rd Generation dodge Cummins. This flatbed comes with a gooseneck hitch already in the bed. The winch bumper is part of the set. Tootlbox have a key to lock and unlock all box a single key. There is rust starting and electrical will have to be sorted out on your own.
Price: $1,000.00
Truck had an active fault for DPF soot load high and SCR conversion efficiency low. After about an hour of Regeneration and approximately 5 gallons of diesel fuel burned the soot load fault went inactive. Might be a DEF ball in ATD preventing the DEF from reaching the SCR Catalyst or defunct NOx sensor. Conversion efficiency has to be 85% or greater at all times to make the fault go inactive. I just replaced the cylinder head from a dropped valve which caused the engine to run dirty so I may try another Regen to see if NOx output from the SCR cleans up some more. I don't think I ever will own a EPA10 or newer diesel engine because of the constant ATD issues. Here's a pic of some of the ATD instrumentation on my diagnostic laptop.
