Tire Pressure Math: Setting Pressure from Axle Weight
(0 reviews)
By Titanium · Nov 24, 2026
The pressure on the door sticker is a one-size-fits-all number. This method sets pressure from what your truck actually weighs, so the tire carries its load without running underinflated or hard as a rock. All you need is a scale, the axle weights, and two numbers off the tire sidewall.
What you need
  1. Weigh the truck the way you actually use it: cargo, trailer and a full tank of fuel. Get the front and rear axle weights separately from the scale.
  2. Read the tire's maximum load (capacity) and maximum pressure off the sidewall. The example tire here is a 265/75 R16 rated 3,042 lb at 80 psi.
The formulas
Single tire (front axle, or a rear axle without duals):
(Axle weight ÷ 2) ÷ Tire capacity × Max pressure = Inflation pressure
Dual rear tires:
(Axle weight ÷ 2) ÷ (Tire capacity × 2) × Max pressure = Inflation pressure
The load-to-capacity ratio in the middle must never go above 1.00. If it does, the truck or the tires are overloaded and no pressure fixes that.
Worked examples
All use the 265/75 R16 (3,042 lb at 80 psi) unless noted.
Case
Load per tire
Tire capacity
Ratio
Max psi
Result
Front axle, 4,440 lb
2,220 lb
3,042 lb
0.73
80
58 psi
Rear axle, empty, 2,860 lb
1,430 lb
3,042 lb
0.47
80
38 psi
Rear axle with RV trailer, 4,280 lb
2,140 lb
3,042 lb
0.70
80
56 psi
Load Range G front, 235/85 R16 (3,750 lb at 110 psi), 4,440 lb axle
2,220 lb
3,750 lb
0.59
110
65 psi
Load Range G rear, 2,860 lb axle
1,430 lb
3,750 lb
0.38
110
42 psi
Check the result
  • Front: the tire should sit flat on the tread with a very slight belly in profile. Usually you only need to adjust about 5 psi either way.
  • Rear: a low number on a lightly loaded truck is normal. The pressure is matched to the load, so it climbs when you hook up a trailer.
Does it match the tire maker's tables?
The method was checked against Michelin's load and inflation chart:
Case
Math
Result
Single tire, 4,850 lb axle, 3,042 lb capacity
2,425 ÷ 3,042 = 0.79 × 80
63.7 psi
Dual rear, 8,820 lb axle, 2,778 lb capacity per tire
4,410 ÷ 5,556 = 0.79 × 80
63.4 psi
Both land within 3 psi of the Michelin chart.
Why not just air them up?
  • Underinflated: the tire flattens and flexes more, which builds heat and rolling resistance. Expect shorter tread life (the article cites up to 25% less), up to 5% worse fuel economy, and sloppier steering and cornering.
  • Overinflated: the footprint shrinks, the ride gets harsher, and the tire is easier to damage on potholes and debris. Raising pressure 10 psi above the calculated number gave no fuel economy gain, only a rougher ride and more wear down the center of the tread. Wear was even across the tread at the calculated pressure.
  • Use a quality gauge. Looking at the tire does not tell you the pressure.
Photo test
On a Black Lion HT 235/85 R16 (3,086 lb at 80 psi), the math for the 1,430 lb rear load is 1,430 ÷ 3,086 = 0.46 × 80, or 37 psi. The tire was photographed from a fixed tripod while pressure went up in 5 psi steps from flat. It showed a mild belly at the calculated pressure. Past that point the belly disappeared and the tire hardly changed shape, but the ride got rougher and the center of the tread carried more of the load, which cuts traction.
Factory numbers and caveats
Chrysler's specification for 265/75 R16 tires on a 2002 Ram 2500 4WD with the 5.9L diesel:
Load
Front
Rear
Light load
40 psi
40 psi
Up to GAWR
65 psi
80 psi
Things to keep in mind:
  • With an 8,800 lb GVWR and a 4,440 lb front axle, the rear can carry at most 4,360 lb. At full GVWR the math gives about 57 psi on both axles, so you never need more than 60 psi on this setup.
  • The two GAWRs add up to 11,284 lb, which is 2,484 lb over GVWR. Do not load the truck to the combined axle ratings.
  • The factory numbers only apply to the factory Michelin LTX tire. If you change brand, size or load rating, rerun the math with the new tire's capacity and max pressure.
  • The tires tested ranged from 3,042 to 3,750 lb capacity and from 80 to 110 psi maximum pressure.
In the Garage
Check pressure once a month and before every tow. Recalculate whenever you add a trailer, a camper or a different set of tires, and write the pressures down in your log.
Sources
User Feedback
