24V 2nd Gen Axles - Tire Rotation: Standard and Dually (1998.5–2002 Dodge Ram 24-Valve Cummins)
By Titanium · Nov 24, 2026
Rotate the tires every 7,500 miles, which is every oil change on the normal schedule and every other oil change on the severe one. In the Garage, set the reminder to repeat every 7,500 miles or 180 days.
Why rotate
The front and rear tires carry different loads and do different jobs: steering, driving and braking. They wear at different rates and can develop irregular wear. The factory manual says rotating on schedule improves tread life, traction and ride, and that other patterns than the one it shows may not give the same tread life. The factory maintenance lists for the 24-valve Cummins call for rotating the tires at each oil change interval.
Before you start
  • Check that all tires on the truck match in size and type. Do not put a temporary spare in the rotation.
  • Directional tires (an arrow on the sidewall) must keep turning the same way, so they only go front to back on the same side.
  • Check tread depth and look for uneven wear. Cupped or one-sided wear points to worn shocks or front end parts, so fix those first.
  • Mark each tire with its position (LF, RF, LR, RR, and for a dually LRI, LRO, RRI, RRO) with chalk so you do not lose track.
Trucks with single rear wheels (four tires)
The usual pattern for a non-directional four-tire truck is the rearward cross: the rear tires move straight to the front on the same side, and the front tires move to the rear on the opposite sides. The 2001 factory manual shows its recommended pattern in a diagram that I could not read from the text version, so confirm it against your owner's manual. Later Ram manuals describe the rearward cross as the suggested method.
Dually trucks (six tires)
A dually has two tires on each side of the rear axle, so rotation is a six-tire job. Dual rears also carry more weight and can wear unevenly, because no alignment covers both an empty bed and a heavy tow. That makes regular rotation more important, not less. Common practice is to rotate every 5,000 to 8,000 miles; the 7,500-mile factory interval fits inside that range.
Pattern 1: the triangle (same side)
Each side of the truck is its own triangle, and tires never change sides:
  1. Move the outer dual tire to the inner dual position.
  2. Move the inner dual tire to the front steering position.
  3. Move the front tire to the outer dual position.
Repeat on the other side. Use this one when you want to keep each tire on its own side, or with directional tires, which need to keep turning the same direction.
Pattern 2: the cross
This one moves tires across the truck so they cover all six positions over a few rotations:
  1. Move each front tire straight back to the outer rear position on the same side.
  2. Move each outer rear tire to the inner rear position on the same side.
  3. Move each inner rear tire forward to the front position on the opposite side.
A tire that goes from inner to outer must be flipped on its rim to reverse its direction of rotation, and the valve stem must end up facing outward. If the wheels do not allow that, use the triangle instead.
Things that limit your options on a dually
  • Valve stems: inner dual wheels use a longer extension than outer wheels. The factory sets a 1 1/2 in. extension on each inner rear wheel and a 1 in. extension on each outer wheel. A tire mounted on an inner wheel cannot just be moved to an outer position unless it is dismounted and remounted, which is a shop job.
  • Mixed wheels: if the front and outer rear wheels are one type and the inner rears another, such as aluminum outside and steel inside, the inner wheels may not fit the other positions. In that case you are usually limited to swapping the fronts side to side and switching the inner and outer duals on the same side.
  • Matched dual pairs: two tires on one side of the axle should match in diameter. A small difference makes the smaller tire scrub on every revolution and wears out both. The factory says dual tires should be matched for wear, and you can check by laying a straight edge across all the tires on that side.
  • Inner tires: inner duals often carry more of the load when the truck is empty and are more affected by road crown, so watch their wear closely when you rotate.
Lug nuts on a dually
Tighten the wheels the factory way:
  1. Use the special heavy-duty dual lug nut wrench, and raise both tires completely off the ground while tightening so the wheels center and clamp correctly.
  2. Put two drops of oil on the interface between the nut and washer before you thread it on. Do not use more than two drops.
  3. Tighten the nuts in the numbered sequence until snug, then again in the same sequence to the specified torque, and a third time to be sure the wheels are seated.
  4. The factory torque is 145 ft-lb for the 3500 dual wheel (8-stud) and 135 ft-lb for the 2500 8-stud wheel.
  5. Recheck the torque after 100 miles and again after 500 miles, then at every maintenance interval after that.
After the rotation
Reset tire pressure for each axle. The rear pressure depends on the load, so use your axle weights and the tire pressure math. On a dually, make sure the two tires in a pair read the same.
Sources
View full Cummins article
  • Views 25
No posts to show
