- Replies 6
- Views 6.2k
cabinet man 3 posts
mopar01 3 posts
Hey all iv been searching all over the internet for a pin out for my 1995 ram 2500 12 valve. the problem im having is all the pin outs are for a 3 plug pcm, mine is only a 1 plug with 60 pins, im trying to diagnose why my pcm has no power or gorund, because the charging system, grid heaters, tach, overdrive, pretty much anything controlled thru that computer is dead, i already changed the ESS engine speed sensor, thats what i was told would cause the problem, and yet still have the same problem, iv traced it to the pcm plug, if i wiggle the plug with the key on, i can hear the grid heaters clicking on an off, if i wedge the plug in an up positon everything works just fine so im trying to figure out what wire is the culpret, please send ur information my way! thanks!
newest information, the check engine light, wait to start light, waterin fuel light and trans temp light are goin crazy comming on and off, as well as relays clicking on the driver side of the hood when i mess with the wires at the pcm, i can even com close to finding the problem cause anthing i touch makes it go crazy, im at a serious loss here please help! THANKS!!!
