- Replies 6
- Views 1.9k
diesel4life 3 posts
rdsutton 2 posts
mr.mindless 1 post
Has anyone here swapped out stub/outer axles on a 98 and put in 2000/2002 axles and bearings? I have looked at and measured both axles and bearings, 02 axle just a bit shorter, inner bearing the same, 02 has the studs in the bearing flange. Both use the same u joint and mount to the knuckle on the 4 bolt holes. My goal is to have the free float rotor with the newer set up. Please include any pics and if you had to modify anything to make it work. Thanks Dave.
