Mongolianthor83
Everything posted by Mongolianthor83
  1. @Mopar1973Man so can you elaborate on how I can figure out how much timing I need to add or subtract. I'm new to this tuning
  2. @@Mopar1973Man so with having a hot rodded vp should I use the pump tap on the quadzilla
  3. @jagwhere did you see the difference
  4. @Mopar1973Manwould you say a small leak after the vp44?
  5. @Mopar1973Manok so today drove 2 hrs in neutral at idle 800 rpm engine load 6-7%. But also new problem fuel pressure is bleeding off overnight have pressure to vp at start but takes about the starts to get truck going
  6. @Mopar1973Manok ill get my injectors replaced or repopped
  7. @Mopar1973Manrpm at 67 are 1888 engine load in park 1% according to cts2
  8. On a side note do you like banks high ram intake? As far as do you feel they help
  9. Haven't installed quadzilla yet I average 18 miles a gallon ibelieve at 65mph im around 1980 ram I have a cts2 monitor I believe that will show engine load. I can have that data tomorrow
  10. @Mopar1973Man ok ill get this info this afternoon unsure of injector pop off injectors are 2 yrs old tires are 35's trans is mostly stock with a heavy torque converter injectors have about 50000 on them
  11. I have compounds HX35 over S471 7x12 injectors hot rodded VP44 with a fass. I just bought a quadzilla adrenaline what are the best daily and fuel saver tunes available
