Downtime
  1. Speedo is squared away using cable on np208 temp I have aftermarket gauge just took out factory and replaced with mechanical my main concern is oil and tach I'd like to use mech oil gauge but I'm not sure if it will throw a code as far as the tach goes I have an aftermarket just don't know where to tie it in
  2. No I've figured out how to use the PCM with this engine through trial and error so I've got it to where I can start it and the fuel pump grid heater etc all work but I would like to get the gauges preferably oem working with the cummins I have complete engine harness but where it goes into the cab what I would call the cannon plug is cut off and I somehow have to go from 01 dodge to 86 ford and patience is a virtue that I lack
  3. I just signed on and could use some help I have a 1986 ford f-350 4x4 with an 01 cummins nv4500 08 Superduty rear 04 Superduty front axles and a bunch of different parts ranging from 1982-2013 I have pretty much squared everything away except for wiring the gauges ie oil press tach temp fuel press sending unit and whatever else I'm missing would greatly appreciate any help
