dmckeehan
  1. Thanks guys. definitely will check the wiring. I'm having intermittent long cranks on start. sometimes it starts perfect, sometimes it cranks for 3-5 seconds before cranking. New injectors, new tubes, 6-7k rail pressure on start. no fuel in my oil. just a pesky code for the cam sensor.
  2. Fighting same issue on my 07 5.9. i have swapped sensors, next step will be the wiring. I have seen one other post about the bolts, now i'm thinking it may be more common than i wanted to believe. if i can't fix it with wiring, next stop will be pulling the cover....
