will
  1. If anyone else has this issue, swap to a ford style regulator, it fixes the headlight flicker, the radio noise and the overcharging all at once.The ford regulator modulates the power to the field instead of the ground, it also senses voltage from the 12+ post on the alternator and has a separate turn on lead. Wish I had done the ford regulator from the beginning.
  2. Has anyone else run into this issue? Having the exact same problem with a 2001 3500 5 speed truck. It's the service truck at the farm I work for... Literally the exact same situation...Thanks!Will
