Gen414
  1. Hey guys, looking for some help on some wiring issues Im having. I've got a '03 CTD motor (had NV5600 behind it), and dropped in 48RE. Rounded up a '04.5 ECM and wiring harness to work with the '03 CTD and 48RE, but the problem I have run into is bulkhead connector, "C-219", as it's called by the CTD Service Manual for '03 trucks. The problem? Well, the '04.5 engine harness doesn't have the exact same wiring/pin locations as the '03 under dash harness. I have all the pin locations and what not for the under dash '03 side. What I need is the pin locations for the engine side of "C-219" for an '04.5 model CTD.Thanks
  2. Well it sounds like a TQ converter problem. Honestly, there isn't much to these auto's, and unless someone just doesnt know what they are doing, not to much they can screw up. I've gone through a number of these trans, and unless they used used parts/didn't adjust bands properly, or maybe your trans cooler had bunch of metal in, didn't do proper flush before new trans install? Again, it sounds like TQ converter, but would like to know more details: Did cooler/lines get flushed? Do they keep reusing the same TQ converter, without having it checked/opened up? What ARE they doing to trans once it's pulled out/opened up/inspected? Anything? Or just looking at it, and putting back together?
