reborn
  1. I had no issues before the brake switch. The multifunction switch seems to work as I forgot to mention that I have a sport model with the four lights. When I switch from low beam to high beam the outside two do not light up and the inside two stay on low beam. I'm not sure how to check the clock spring. I did the gauge cluster diagnostics and no codes came back.
  2. I can't seem to figure this one out. I was having trouble with my brake light switch, got that replaced and working. Now i don't have high beams, cruise control, or day time running lights (Canadian). I have replaced the DRL module and have confirmed that my P/brake switch is working properly but can't think of where to go from here. I have followed the wiring schematics and still can't find anything. Any help would be greatly appreciated.
  3. I have the fog ligts and the switch, my truck is the sport edition. The problem the guy that owned the truck before me for some unknown reason he took the wiring harness. Tylor
  4. Thank you for all your help. I'm going to have to look into this a little further.
  5. I have been told that the wiring for the fog lights is part of the main lighting harness and not able to be ordered separatly. Is this true and if not does anybody have a part number or pictures of where it connects into the main harness so I can make the fog light harness. Thank you,
  6. For your truck I believe you can run up to B20 which is 20% biodiesel mixed with regular diesel. You could check your owners manual or check with the stealership. They can tell you what your max is without voiding any warranty that you may have left. Any place I've seen selling it is usally B20. Tylor
