cp734
  1. Sorry guys, i have been out of town for a while. I did get scanner codes from the ECU. P0216,P0230,P0380,P0252,P0251. My assumption is that my ingection pump is shot. Do you recommend a reliable source for these? Thanks very much for everyones input, it is very helpful.
  2. It is a 2001, 6 spd. Plain stock, no mods. Thanks
  3. I have not used a scanner yet. I will see if I can acess one. The only code on the Odometer readout is P1693. Fuel pressure is 7psi. Only a small amount of black smoke. If I toggle the key switch real fast on/off it clears up and runs great. This fixes it every time?
  4. When pushing down on accelerator pedal,sluggish response almost dead pedal,truck sounds rough. If you cycle key switch on/off, truck clears up and runs fine.it only does this intermittently, but cycling the ignition switch always resolves the issue. Any ideas,bad relay or switch contacts?
