Firegrazer
  1. I unplugged the Edge today and the problem completely disappeared. I guess now I have to see if it's a bad/loose connection somewhere or if my Edge unit is just bad. The monitor has been randomly shutting off when it gets really hot outside but I thought that was due to how hot its been down here this summer but I could be wrong. Any ideas on where to start looking for a bad connection?
  2. I've used a code reader and it isn't throwing any codes at all. I have a fuel pressure gauge and it it is showing ~15psi consistently and nothing odd happens to fuel pressure when the issue happens. I've tried resetting the APPS and none of that changed the issue. I'll try taking the Edge off later. I took my APPS off yesterday just to look at it and it smells slightly like burnt circuitry.
  3. I have a 1998.5 3500 24 valve with an Airdog, fairly new VP44, and Edge chip. I had my nv4500 rebuilt recently and ever since when I'm driving I lose power for a split second before it goes back to normal. The engine does this even in neutral if I ramp up the RPMs slowly or rapidly. Any help would be great.
