1995-12v-oilburner
  1. I have been having lockup problems I've tried everything to fix it new tps. Temp senor. battery reminals. And tcc/od noid and still coming out of lock up under light acceleration even with the lock up switch on. So today I tested the middle wire on the trans and have 12.24volts with key on and as soon as I start the truck it jumps up to 13.60 or so then driving down the road with multimeter in cab it jumps up even higher under acceleration when it comes out of lock up to about 14 volts. So I'm wondering if this would cause it to come out of lock up. If I go really easy into the throttle she will stay locked. Idk what else to try I'm about sick of messing with it any help will be greatly appreciated I just want my truck to drive the way it used to.Truck is a 1995 dodge cummins with a 47rh. I just changed trans and torque converter because of this problem only to find out my trans and tc was fine its something else. Any help would be greatly appreciated. My first post here let me know if I'm forgetting something thank you very much
