Irondime
Everything posted by Irondime
  1. got my truck going about a month ago. it was the remanufactured ecms the whole time. I mailed my original fried ecm to a repair service and it fixed the dead pedal. place where i bought the remanufactured ecm won't give me my money back because it's been more the a year. they told me that there is a difference in the programming for 05 and 05.5s and it was their mistake. they are mailing me back the reman ecm after I sent it back for "testing". truck has been running great. got lots of new parts it didn't need. I did get some nice battery cables from genos. cost me a couple grand in the end. the $200 repair on my original ecm is all it would have took the whole time. I'm so pumped about having my truck back i don't care
  2. what's up everyone. my truck is still down. I am looking for a new TIPM (fuse box). would like to buy a new one but I can only find used. any ideas? # is p05026036ac. thanks previous post said I tried one already but now that mechanic now has doubts about the one he tried. so I just wanna buy a new one
  3. my truck is still down. towed it to the dealership and they wanted to put one of there ecm's in it for $2650 with no guarantee it will fix it and no returns. its at a different shop now. tried a new fuse panel that didn't help. got a mass airflow sensor on order now to see if it might fix the problem.
  4. Really want to trailer it to dealership and get a flash. They said they'd do it for $100. The company i got the ecm off of was sure they programmed it correct. This is the second ecm they sent me. First one did same thing. Everything was ok except dead pedal. Almost has to be that the software they are using was wrong on both or a wiring issue. All wires from apps go to the ecm then it's grounded or is there a wire from that 5 or 6 prong plug at the apps that goes to a ground somewhere that may have arced when I fried the ecm
  5. Ok I got the full version of torque. Made a custom screen with all the accelerator gauges. Most don't read anything at idle. One reads 0.2 . Nothing changes when I press the pedal. Just idle. Quick question. The pedal apps sends signal to ecm to accelerate then ecm sends signal to what?
  6. What info am I looking for with this elm327.
  7. Nope won't work with my el cheapo
  8. Ok my elm 327 came today. It came with a little disc and no directions. What app should I download to my phone and will I need to do anything with this disc Started messing with it. Tried 5 different apps. Most need a paid full version. What info am I looking for? Also getting code p1755
  9. They are cheap. Mine should be here tuesday Should have mentioned codes I'm getting. P2122 and p2128. Apps codes. Also have more codes but I don't have my list. I will post them tomorrow
  10. I do not. I will order one if it will help give me some answers.
  11. Hello. I got a 2005 5.9 I fried the ecm battery cable arced while it was running. Truck would crank but not start. Don't know what else it may have fried. So I got a remanufactured ecm. Truck started right up but I had dead pedal. Tried to reset it a few times but still wouldn't work. Procedure I used was unhooking batteries with key on overnight. Key off, connect batteries. Key on but not start. Pedal to floor slowly then back up slowly. Key off. I've read that is for earlier models, that the 05 with the apps built into the pedal resets every time u key on. I don't know. So I ordered a new apps pedal assembly thinking I may have fried it also. Can't get it to work either. Any advice is greatly appreciated.
