Jared Riley
Everything posted by Jared Riley
  1. Ok so i double checked everything, and started it up this morning an it started high idleing after about 5 mins an the apps is still doing the same thing, but it works now so i guess ill just wait an see if it continues to work
  2. I believe i followed them to the tee, i will recheck with my meter again tomorrow
  3. Alright so i installed the new timbo apps and i am still having the same problem, anything else i should take a look at?
  4. Out of curiousity could it be the alternator outputting ac noise? I have never tested it, can i just pull the alternator fuse to see if that cures it?
  5. Alright i will try a new apps and see what that does
  6. Alright so i unplugged the apps an then started it, edge jwa monitor shows 0% on throttle position, i let it idle for 3-4 mins and it didnt idle higher, i disconnected the batteries and i will try again after work
  7. I will deffinetly be ordering from you guys if it ends up being the problem,
  8. Alright i will try that in the morning, lol its not a dumb idea if it works
  9. Alright so i reset the apps for giggles to see if it would work, it did not, so should i order a new apps or is there anything else i should do? I appriciate the help alot
  10. Alright ill try reset and if that doesnt work i will order a sensor, Thank you for your help, i will keep updated
  11. i have never touched the apps, i believe its original as the truck only has 120xxx on it, i have no dead pedal in it but i can try and reset the apps tomorrow
  12. So could it be that the tps is on its way out you think?
  13. I purchased the high idle kit from this website, i installed it and it idled up to 1200 for about a minute then went back to normal operating idle, i tried turning truck off an reatarting it and it wont high idle, on my edge jwa monitor it shows the correct intake temp, only thing i noticed is the throttle position flashes 1% then back to 0%, could this be affecting it? i activated the settings in the computer by using a smarty touch
