DirtyDodge5.9
  1. I think it might be the dimmer switch cause the passenger side isn't getting ground at the right time
  2. Just took the meter out again and found out that I have 12 volts when the lights are off, none when they are on. Maybe a relay or something?
  3. Tried a new switch today and that didn't work, broke out the multimeter and have no juice at the headlight plug, kinda lost at this point any help is appreciated
  4. I swapped in a new fuse, but that didn't seem to work, just seemed kind of odd that they both burned out
  5. My right headlight started acting up the other day in my 2000 Ram. Left works as it should high, low beam, markers etc. the right however just the marker comes on and I don't believe the bulbs are bad I think I lost my ground. Wondering where the right headlight is grounded
