Roy220
  1. Did the key code deal...Got 12 and 55..so that means connection to abs sensor ok? Played around with emegency brake...the switch was stuck ...went for drive, still lights on...
  2. Hey everybody..95 ram 12 valve...I know this subject beat to death...have been looking around, search function little confusing..and not allowed to look at diagrams and pictures yet..My Abs/brake light on. Replaced brake light switch,replaced rear abs sensor..check wire from switch to wire harness in back, Cleaned all ground wire in engine bay. Question my fuse holder in engine compartment has place for abs fuse,but only one spade other side missing spade? Was it broke off? or do i not need fuse? When i do start it the brake light seems to try and go off..but no change in abs light..Does my emergency brake have a switch? Have not looked under steering wheel yet but going to see if anything is noticeable.Air bag light on dim but from what i read its not connected.How do you reset abs controller? Help Please........
