Honky Whip
Everything posted by Honky Whip
  1. I ordered the DOR bar too. After waiting and getting the run-around for 2 months, I pulled the plug on that and went with the DT Pro Fab. Happy so far. DOR operates at the speed of smell, and getting my money refunded was like pulling teeth. There are definitely better options out there!
  2. Mine was very stubborn, had to use a pitman arm puller to get mine loose at the frame end. Worked great.
  3. Go with Moog problem solver. Check your ball joints, tie rod ends, and control arm bushings. Check your steering box for play. Replace all worn out parts. If you plan to do a lift in the future, go with this track bar now, and you won't regret it: http://www.dtprofab.com/DTP02100XHD-TRACBAR-KIT-94-02-STOCK-TO-4-LIFT-_p_352.html
