D8675309
Everything posted by D8675309
  1. I called them yesterday so that i knew exactly what they wanted me to test to make sure I could figure out whether it was something on my end or theirs. By the time that I made it home to test it, they were already closed. I just wanted to see if anyone else has had this problem and knew if it was something they fixed themselves or if it was Quadzillas product itself
  2. I have been having alot of problems with my Quad that I bought 3 weeks ago. First I got the p0237 code. I replaced the map sensor. Then I got the p0236 code. I was checking all of the voltage to and from the Quad to see what could possibly causing my issues. Everything has proper voltage except the red/black wire going from the Quad down through the boost fooler to the map. Even on the inside, on the board, no voltage which if i remember correctly should be 5v. Would this be causing the p0236 code? If so is it fixable on my end or is it possible that I was sent a Quadzilla with a bad board?
