JamesL8816
Everything posted by JamesL8816
  1. Any other tips or parts that will ensure longevity out of the truck
  2. Alright so after about 10 hours total, the fuel tank is clean, lines cleaned with no leaks, new filter, new vp44 and help from a number of people with ways to test, the ol blue b**** is back on the road. Thanks yall
  3. A local shop that gets them directly from bosch. They said it's the one that has the upgraded electronics New vp44 is in and just waiting to get my fuel pressure gauge back, then to bleed the lines and do one last check on my fuel psi before I test fire
  4. Old vp44 is replaced under warranty now time to put it in
  5. Good to go man, thanks for the quick replies and help. I will try in the morning and update if it's dead. And if it is I will update after the new pump is installed. Now would it also be a good idea to go get a new fuel pump and install it as well if the vp needs to be replaced
  6. Sounds like something to try in the day light. So if it fails to start then it is for sure the pump?
  7. I have not, didn't know if that would void the warranty on it and dont know how to do it
  8. Its 15 on the return off of the side of the pump with the pump running and it's a carter, I know it needs an upgrade to prevent future problems
  9. Both the key trick and a scanner, and no mods at all to the truck That's why the only thing I can narrow it down to is the vp. Just seeing if there is any other cause that would make fuel come out of 2 of the lines and not the rest, the pump is under warranty and was put in back in June along with a new lift pump and fuel filter was just replaced today. Dropped and cleaned the tank, all the lines from tank to vp and still nothing. No trash was in the tank or lines but I figured why not drop it and check just in case
  10. It turns over but no start And no codes
  11. So I have an issue and I'm hoping it's not my injection pump. I've check all my fuel lines for leaks and everything is working as it should, no air all the way from the tank to the return line off the side of the vp44. Truck will not crank. Went to bleed lines 1 through 5 at the head and only getting fuel to lines 1 and 4.
