Silver bullet 01
  1. So I installed my high idle switch this after noon and I'm have issue with the temp gauge shooting up to +200 in 6cyl settings. I tried shutting the truck down then switching settings. Then starting it back and the issue goes away in the mpg setting and 3cyl settings. I tried the 6cyl setting again and same issue. I uninstalled the unit now it goes into 3cyl high idle with out the unit being installed. I have it set to the off position now and it idles normal now. Any ideas on trouble shooting the issue. I followed all the install instructions and check the wiring for any pinched wires or connecters not being plugged in all the way and everything checked out.
