FlightRN
Everything posted by FlightRN
  1. I have the heated, power mirrors. The driver side has not worked since I bought the truck, the passenger side just went out this year. Any hints on common failure points? This might be just the excuse I need to buy the flip up tow mirrors though.
  2. So I replaced all the dried out connections, still no improvement in HVAC selector. Any chance there is a few more rubber connections on the cab side of the firewall?
  3. Looks like the connections are dried out but not fully cracked through yet, could be a bunch of micro leaks I guess. Anywhere sell a full connection kit?
  4. Over the past few months, my vent selector switches to defrost and stays there. Only when I first start up the truck does it switch to what the selector is at. All other vacuum actuated things work... no problems with 4x4 or cruise. Looked over the vacuum system and cannot find any leaks.I went behind the dash and pulled off the yellow hose running to the zone selector vacuum actuator and applied a little suction to the actuator and it works fine, but does take quite a bit of vacuum pressure. Does the zone actuator become worn out or brittle?Thanks for the help, I have run out of things to try.
