mmoyle
Everything posted by mmoyle
  1. Hi All, I have an 02 2500 6sp diesel truck that has a bad AC compressor that I plan on replacing. I decided to buy the kit from rock auto that contains the compressor, condenser, orifice tube, accumulator, and some seals. I figured since the truck has the original components and the kit was not bad in price, I would just install the new kit. This is the first time I am replacing items like and I want to make sure I do this properly and don't screw things up. Not willing to pay the prices to have others install these components. I have been doing my research and I think I have everything I need, but I have a few questions I was hoping you guys could help with: 1. Pag Oil - Since I am replacing the compressor, condenser, accumulator, and orifice tube, it was a little unclear to me how much PAG Oil I should be adding to the components. I found a section in the service manual that states the following: Refrigerant Oil Capacities A/C System 6.2oz Accumulator 2oz Condenser 1oz Evaporator 2oz Compressor- drain and measure the oil from the old compressor. When an air conditioning system is assembled at the factory, all components except the compressor are refrigerant oil free. After the refrigerant system has been charged and operated, the refrigerant oil in the compressor is dispersed throughout the refrigerant system. The accumulator, evaporator, condenser, and compressor will each retain a significant amount of the needed refrigerant oil. 1a. So, where I get confused is if I need to add oil to the accumulator and condenser separately or will the oil get dispersed throughout the system? 1b. When replacing the compressor, should I measure the amount of oil that comes out of the old compressor and only put that amount back into the new compressor? What is there was some oil loss over time? Not sure if that was the case, but just a question I had. Once I replace all the components and vacuum test the system, I plan on taking it to a AC shop to have them recharge the system for me with the proper 1.87 lbs of refrigerant. Thanks in advance for your help. Mike
