bsmith
Everything posted by bsmith
  1. I did the job last week, didn't start the truck till yesterday. Messed with it yesterday and today trying to get the air out. I turned the wheel side to side while pumping the brakes, with the truck on and off. It sometimes feel normal but goes back to feeling like no power steering at all. I've added fluid cause it sounds low, but it overflows after turning it side to side mutiple times. I'm almost to the point of pulling it off to make sure I did the job right. Should my pedal feel really stiff? Thanks for the reply! --- Update to the previous post... Ok I messed with it some more today without luck. It does sound better, it isnhumming and foaming out the top. It is still too hard to steer to drive. Feels like it doesn't have power steering at all. Also I pumped the brakes so hard I mus hae cracked a line or something cause I had to bleed the brakes. I'm pretty close to pulling it back off and re installing it.
  2. I resealed my hydoboost according to this write up, but I can't seem to get all the air out of the lines.I turned it lock to lock mutiple times while pumping the brakes. Took it for a ride down the road. Still no luck.Any help is muchly appreicated.ThanksBrianTo add, it sounds like its low on fluid humming sound. I've added fluid but it ends up over flowing once it gets warm.
