LK89
Everything posted by LK89
  1. Is there link to these mods? I still havent had a chance to further diagnose my issue?
  2. I hear ya on this, I have put 4 alternators in the truck since I've owned it, 1 failed of normal use, 1 failed of oil spray all over it from a failed head gasket, 1 burnt the positive terminal right off and this last 1 has been good for about a year right now, charging @14.1v tho I have not done an amperage output test yet. Both batteries were replaced at the same time about a year and a half ago, when I tested them I used our digital snap-on tester at work, they are 730cca batteries and both put out 685cca @12.6v. I will have to try a carbon pile perhaps. I've noticed that it more doesnt do it when I jump in the truck and start with the key as I rarely let the grid heater cycle, but when I remote start my truck, the heater cycles. As for any other weird symptoms, no, none that I've noticed. Thanks I will look into that side of things more!
  3. My indicators have not changed color at all, everything else on the cluster works as it should.
  4. Yea I'll have to check it out, my old plug pins tend to push out when connecting a scan tool, I have to hold them from the back as I plug it in
  5. Also I should mention that sometimes it does not reset, last week i got about 6 startups with it not resetting and now ever since it has done it everytime except not once today
  6. Batteries tested individually, all cells full, both hold full charge and never give any starting issues. IOD fuse also good, I did try pulling it out before, but when i do I lose interior lights, so I'm sure it's working
  7. Looking to figure out what may be causing my trip meter to reset itself everytime the truck is turned on. List of things I have done: Load tested batteries Cleaned all battery connections Checked all fuses Cluster test The trip counter works perfectly fine while driving, no errors on the cluster test, my clock never resets time, only the trip meter. Everything else works fine. Has my cluster gone bad? It's as if the cluster is losing constant power. Any help/input appreciated.
