CTDaddict
  1. http://www.factorychryslerparts.com/products/DODGE/1998/RAM-3500-59L-I6-Cummins-Turbo-Diesel--4-SPD-AUTOMATIC-47RE/WIRING-Headlamp-to-Dash/4373172/56020523AD.html [TABLE] [TR] [TD=class: productDetails_keyValue]56020523AD[/TD] [/TR] [TR] [TD=class: productDetails_keyName, width: 200px]Fitment Notes[/TD] [TD=class: productDetails_keyValue] [/TD] [/TR] [/TABLE] [TABLE] [TR] [/TR] [TR] [TD=class: productDetails_keyName, width: 200px]Your Price[/TD] [TD=class: productDetails_keyValue] $ 1880.00 [/TD] [/TR] [/TABLE] [TABLE] [TR] [TD=class: productDetails_keyName, width: 200px]Installation Instructions[/TD] [TD=class: productDetails_keyValue]N/A[/TD] [/TR] [TR] [TD=class: productDetails_keyName, width: 200px]Additional Notes[/TD] [TD=class: productDetails_keyValue] w/R.W.A.L., w/R.W.A.L. & Overhead Console Type II, w/R.W.A.L. & Trailer Tow, w/R.W.A.L. & w/o Daytime Running Lamps, W/RWAL, w/RWAL & Overhead Console Type II, w/RWAL & Trailer Tow. [/TD] [/TR] [TR] [TD=class: productDetails_keyName, width: 200px]Alternate Stock Code[/TD] [TD=class: productDetails_keyValue] 56020513; 56020513AB; 56020513AD; 56020520; 56020520AB; 56020520AD; 56020523; 56020523AB; [/TD] [/TR] [/TABLE] Got me swingin.
  2. MnTom, I thought of swapping the dash too, I'm kind of partial to the 98 dash so I figured I'd leave that as a last ditch option.AsTross, I hear what your saying but I want to keep the engine bay as neat as possible.Mopar, That diagram looks like a 24v so I assume that was relevant to AsTros' truck. In case this will help someone else, here's where I'm at. 98 The dash harness is the same part# gas or diesel, the same goes for the headlamp to dash harness. So I'm going to disconnect the 95 engine harnesses from the 95 headlamp to dash harness and see how it will wire into the 98 headlamp to dash harness. I will let you guys know what I find out.
  3. Can you be more specific? 2 computers and an extra harness? I'm interested in what you're saying, I'm just not following sorry.
  4. Transmission is an automatic 47rh, 241 hd transfer. I'm pretty much set to swap it over besides getting the dash hooked up. I'm trying to figure out if Dodge at least used the same colors on the wiring between 95 and 98, if so I could probably swap the 98 c134 connector in place of the 95 c133 connector. If not, omg, I will have to figure out which colors for which circuits on each truck. Unless there is a way to keep the 98 headlight to dash harness and wire in the ecm and engine harnesses, I'm not sure. If I hadn't overlooked the connector difference to begin with I would have gotten a 47re trans with a 98 computer and harness:spend:. Oh well, live and learn.
  5. Hi guys, I'm not having much luck finding info on this particular swap. I'm repowering my 98 3500 from a 360 gas to a 95 12 valve and I'm wondering if anyone else has any insight on the swap as far as wiring. I have the 95 engine harness with the ecm and I also have the headlight to dash harness for the 95 diesel which of course doesn't plug into the 98 dash harness. Would it be possible to wire the diesel ecm and engine harness into the 98 gas headlight to dash harness? What about swapping the connector from the 98 gas headlight to dash harness to the 95 diesel headlight to dash harness? Any ideas might help and would be much appreciated.
