04cummins5.9
  1. Does this mean my pressure relief valve has failed? VID_20200210_143702857.mp4
  2. Thanks for the information. I am aware of the hazards. I never thought of it pooling up though. Is there an ASD relay on this truck?
  3. Hi everyone. I'm new to this site and forums in general. I have a 2004 Cummins that will crank but not start. This problem started many months ago with crank times getting longer and grid light coming on while driving. Finally it wouldn't start at all. Took it to mechanic and he replaced all 6 injectors with new bosch. He also replaced injector orings, supply tubes, FCA, and air temp sensor. I got the truck back and it drove fine for a couple of weeks and then wouldn't start. Took it back and he replaced an injector line that didnt seal properly and the starter. He claimed starter was not spinning fast enough. After work the next day it took about 5 10 second cranks for it to fire. Ran fine on the hour trip home. The next day no start again. It is throwing these codes, 0193 0113 0237 0069. I sprayed a little ether on Inside of air box lid and it still won't start. Please help! TIA! Also I can hear the lift pump and fuel pours out of water separator when open and pump buzzing. I also took an injector line off and cranked but only a little fuel came out. (Not sure if it's supposed to be more) The tach reads about 200 rpm while cranking.
