Twobarrell
Everything posted by Twobarrell
  1. I may just end up doing the same thing.
  2. Reflector style. From a company called speed daddy off of Ebay Oh, you wasn't asking me. Lololol
  3. What brand are your housings, just curious.
  4. If you look closely, on the right, you can just barely see the bulb behind that center peice. What you see on the left is just the reflection of it. There's just ALOT of reflection going on in there. Lol. ???????
  5. No, single bulb application, just like my old headlights. Oh, almost forgot, I was able to swap the wires and get my high/lows to work right!⚡⚡⚡??? If you look closely, you'll see it's just the reflection of the bulb.
  6. These are what mine look like.... I ordered them off of Ebay. Company called speed daddy These are what I bought Wonder if my aftermarket rings would work with those LEDs. ???
  7. Nice! You still using stock housings? If I get these, I have aftermarket housings. I don't have the stock twist lock rings no more. ?‍♂️?‍♂️?‍♂️?‍♂️
  8. Did you have to buy load resistors?
  9. Yeah mine aren't that fancy. Lol I mean the whole kit was under $100. The led bulbs where only $30. Lol plus how do I know what the right adjustment would be if I had those???
  10. That's how a video told me to put them. Should've just bought some headlights that are from a legit brand. Lol
  11. What do you mean? Like twist the bulb? I have it where the LEDs are on the left and right.
  12. I did the 25 feet thing and there was just too much light everywhere so I lowered them as far as it would go.?‍♂️?‍♂️?‍♂️
  13. These cheap sob's. Lol It was a conversion kit. Housings and LEDs
  14. Got another problem, these suckers are so bright it is literally impossible to aim them at 25'. Got them as low as they go, watched plenty of videos and there is no definitive line from my lights on the wall to really go off of. Cheap aftermarket headlights. Lol. ?‍♂️?‍♂️?‍♂️?‍♂️
  15. Thanks LorenS! I will check it out
  16. Well I watched a vid that told me to swap purple wire with white stripe and orange wire with red stripe around on the truck plug. But that still didn't help. Can't do it with the headlight plug cuz the pins are molded into the dang plug. But I'm gonna have to have play with the pins on the truck side right????
  17. So I did a headlight upgrade on my 1998 dodge 2500 and my lows are actually brighter than my brights. Can someone help me out??? Thanks It's an led upgrade also.
