Kane
Everything posted by Kane
  1. I’m thinking that when I replaced the heater core I may have messed up a vacuum line. How do I check to see if I did?
  2. Gotcha, so what would be an easy way to check if the blen door isn’t working before replacing it? If there is one that is
  3. Hello, I have an 01 24 valve with no heat or Ac. I don’t really care about the AC, but would love to have heat. I have replaced the heater core and the thermostat, but still have no heat. When I used to try to run the heat, I would end up with a puddle of coolant on the floor. I’m not sure if the coolant stopped leaking after I replaced the heater core, simply because there was already so much on the floor and I’m afraid to try it again since I just finally got the carpet dry. Either way though, still no heat. I’m thinking it’s either the blen door or vacuum line, but would like a second opinion. Thanks!
