EGTittey1
  1. He said it was missing I didn’t see old injector
  2. I’m on the same page here what’s odd is he had the set of 6 sticks cleaned and flowed at a reputable place a d the spec sheets show obvious fuel duration and why didn’t they ask him if he planned on putting 6 stock and 1 dap.. makes no sense but with discussion before the job I made sure to contextually discuss that with him and on contract.. so at the end of the day I’m still wrapping my head around this.. he did Install a new turbo recently as well but it’s not anything other than a tow pig trucks not even nice in anyway but he might be looking for a new motor I see that angle
  3. Ok question to the crowd! what would you do ? A customer paid me to just put a set a used injectors in I agreed with a disclaimer.. while putting them in I noticed that one body had DAP engraved and IQA code was way off or different language/ used same code for that cyl that was programmed allegedly he had them flowed at a pretty decent local shop here In nowhereville.. the trucks setting a #6 cylinder white smoke horrible.. he failed to mention its a stock tune or that his turbo was seized recently and he had it replaced at a flying Jim shade tree location outside of wtfville.. so is this a tunable thing or a pull apart bc it’s Not fixable to run one dap and the rest stock? Or maybe adjusted with cal?? He’s not giving me **** for anything he just wants back to regular operations and idk what to do.. help out guys
  4. Ok question to the crowd! what would you do ? A customer paid me to just put a set a used injectors in I agreed with a disclaimer.. while putting them in I noticed that one body had DAP engraved and IQA code was way off or different language/ used same code for that cyl that was programmed allegedly he had them flowed at a pretty decent local shop here In nowhereville.. the trucks setting a #6 cylinder white smoke horrible.. he failed to mention its a stock tune or that his turbo was seized recently and he had it replaced at a flying Jim shade tree location outside of wtfville.. so is this a tunable thing or a pull apart bc it’s Not fixable to run one dap and the rest stock? Or maybe adjusted with cal?? He’s not giving me **** for anything he just wants back to regular operations and idk what to do.. help out guys
