Seat Belt Timing Module
It is possible to wire in a toggle switch and turn the seat belt lock on or off with that. I did that years ago while I waited six months for a replacement seat belt timer module from Dodge.  It is a little black plastic box with a chip in it and a ball bearing switch (in case the vehicle turns over or on its side). When mine went bad it drained the batteries down so low that one froze. Wasn't too happy about that.
Thanks Old Blue-
We're rewiring that SCTM right now so the power comes from the key and not directly from the battery. I tried 2 other SCTMs and all 3 were running the retractor solenoid round the clock, so figure the issue is with that solenoid, not the SCTM.
