Announcing a Full Synthetic At current Petroleum prices.
Hello to All.
Here is hot off the presses announcing a Synthetic which can fit all user needs, (Diesel and Gas), and At current Petroleum CJ-4 specs, and Backward compatible as a Fuel efficient and standard Drain lube product.
AMSOIL OE 15W-40 Synthetic Diesel Oil provides excellent protection and performance in both on- and off-road diesel engines for the original equipment manufacturer’s recommended drain interval. It meets API CJ-4 specifications and is suitable for both modern and older diesel applications. AMSOIL OE 15W-40 Synthetic Diesel Oil exceeds the higher performance demands of modern engines and withstands the stress of heat, soot and acids to help prevent deposits, wear and corrosion.
At $4.67 Qt. /$ 18.67 Gal. Delivered in 55 Gal lots, this is approaching Cl/CL spec lubes, and has met specs for all engine drain intervals. Designed to allow users to maintain current servicing schedules for all component intervals, it offers the confidence of a true synthetic from the company that introduced the First A. P.I. Synthetics to consumers in 1972.\
NOTE: There are several new oils as well.
Break-In Oil (SAE 30)Designed for High-Performance and Racing Engines
Z-ROD 10W-30 and 20W-50 specially engineered for classic and high-performance vehicles.
Allow me to assist your operations in reducing Maintenance costs and extending the life of your Components and the range of the fuel you pay for with cash.
Best Regards and Thank you in advance, for your call, at any time.
OE 15W-40 Synthetic Diesel Oil (OED)
Formulated for Excellent Diesel Engine Protection and Performance
See Pricing Information or Place an Order
Package sizes include:
1-Quart Bottle
1-Quart Bottles (case of 12)
1-Gallon Bottle
1-Gallon Bottles (case of 4)
2.5-Gallon Bottle
2.5-Gallon Bottles (case of 2)
30-Gallon Drum
55-Gallon Drum
AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API-qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL, The First in Synthetics®, to do the best job protecting your engine.
Meets Emission System Requirements
AMSOIL OE 15W-40 Synthetic Diesel Oil is a low-sulfated ash formulation that meets the requirements for low-emission quality diesel oil and protects under the most severe conditions found in modern diesel engines. It is compatible with all exhaust treatment devices and is designed for engines equipped with diesel particulate filters (DPF).
Extreme-Temperature Performance
AMSOIL OE 15W-40 Synthetic Diesel Oil is formulated for improved heat and oxidation resistance over conventional petroleum oil for cleaner engine operation, maintaining power and fuel efficiency for superior engine performance. Its dependable cold-temperature flow assures easier start-up and improved post start-up protection.
Resists Oil Consumption and Emissions
Due to its low rate of volatility (burn-off), AMSOIL OE 15W-40 Synthetic Diesel Oil is able to reduce oil consumption and emissions during operation. It maintains its excellent film strength even during high-temperature operating conditions to ensure dependable protection, performance and fuel efficiency.
Controls Soot-Thickening and Wear
AMSOIL OE 15W-40 Synthetic Diesel Oil is formulated with premium synthetic base stocks and robust detergent/dispersant additives that keep soot particles from agglomerating and forming larger wear-causing particles. The AMSOIL OE 15W-40 Synthetic Diesel Oil formulation allows for optimal soot-related viscosity control to maintain stay-in-grade performance.
APPLICATIONS
AMSOIL OE 15W-40 Synthetic Diesel Oil is recommended for diesel engines and, where appropriate, gasoline engines requiring any of the following specifications:
• API CJ-4, CI-4+, SM...
• ACEA E9
• DDC 93K218
• Cummins CES 20081
• MB 228.31
• CAT ECF-3, ECF-2, ECF-1-a
• Mack EO-O Plus
• Volvo VDS-4
• MAN 3575
• Renault RLD-3
• MTU Type 2.1
COMPATIBILITY
AMSOIL OE 15W-40 Synthetic Diesel Oil is compatible with conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will reduce the performance benefits.
Aftermarket oil additives are not recommended for use with AMSOIL motor oils.
SERVICE LIFE
AMSOIL OE 15W-40 Synthetic Diesel Oil is recommended for the intervals stated by the original equipment manufacturer (OEM). Refer to the owner’s manual for specific oil change interval recommendations. AMSOIL recommends the oil filter be replaced at each oil change as recommended by the OEM. When using an AMSOIL By-Pass Filtration System, refer to the By-Pass Oil Filter data bulletin (G498) for more information.
HEALTH & SAFETY
This product is not expected to cause health concerns when used for the intended application and according to the recommendations in the Material Safety Data Sheet (MSDS). MSDS’s are available upon request at 715-392- 7101 or on the AMSOIL Website. Keep Out of Reach of Children. Don’t pollute. Return used oil to collection centers.
For AMSOIL warranty information, click here.
TYPICAL TECHNICAL PROPERTIES
AMSOIL OE 15W-40 Synthetic Diesel Oil (OED)
15W-40
(OED)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 14.5
Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 101.3
Viscosity Index (ASTM D-2270) 147
CCS Viscosity @ -20°C, cP (ASTM D-5293)< 5500
Flash Point °C (°F) (ASTM D-92) 230 (446)
Fire Point °C (°F) (ASTM D-92) 248 (478)
Pour Point °C (°F) (ASTM D-97) -38 (-36)
NOACK Volatility, % weight loss (g/100g) (ASTM D-5800)< 8.0
Total Base Number (ASTM D-2896) 9.0
High-Temperature/High-Shear Viscosity, cP (ASTM D-5481) 4.3
