Power seat Qs
01 2500 driver side seat the switch forward and back work fine but there are other switches for up and down and tilt that are not working I swore I checked this when I first saw the truck, Iv only had the truck for 1 week, haven't looked for a bad fuse but I figured if the fwd/aft switch works the same fuse shuld work other switches ?
  • Replies 3
  • Views 1.7k
I have the same issue with my power seats. If I push the other buttons and wiggle a little I can usually get em to work. Also I did notice that the other movements are not as apparent as the fwd/aft movement. I think the switch its self is bad but I have not confirmed it.
I may try some contact cleaner in the switch if that dont help then 67.00 for a new switch from Dodge i guess.
Before you replace it you should test each function to make sure they work also. Replacing the switch may not cure it if the actual function is not operating correctly.
