Thor - Looking more like a normal truck once again!
(0 reviews)
I managed to get alot done today on Thor. Everyone was pitching in between Mark and Suzanna. We temporarily rigged up the AirDog fuel system so I could move the entire truck outside. I've got a trick I'm going to show on Thor that I'm doing for a AirDog soon. Already got the straw done in the sender basket. Then pulled Beast up with the trailer and used the a-frame to unload the new bed for Thor. Then, Thor was fired up, rolled out the door, lifted the bed up, and carefully lowered the bed back on Thor. I've got a problem with the brake lights not working, so I've gotta chase that problem quickly. I'm very pleased with the bed and the tailgate. The tailgate has a few minor dents, and then the bed has a few extra holes but is in good condition small dents. I've got more projects to do to this truck like sealing the radiator (another trick I wanna try). I've got an idler pulley for the fan belt to install. Then a full oil change. Then I'll have a working truck to use when I'm busy fixing Beast.
What I figured out tonight just looking over wiring diagrams and quick test of power at the 26 Fuse in the TIPM and found both terminals of the fuse to be dead without power. I've got a post over on the forum...
0 Comments
Recommended Comments
