Winter's Coming — Time to Move Back Inside
Hey everyone,
If you've been anywhere near my neck of the woods lately, you know the good warm weather isn't going to last much longer. Fall is creeping in fast, and it won't be long before the days turn cold and rainy for good.
That means my outside work is on borrowed time. I've been putting in as many hours outdoors as I can while the weather holds, but once the rain and cold move in for the season, I'll be shutting that down and heading back inside.
Before that happens though, I've still got a solid list of outdoor jobs to knock out while the weather allows it:
Beast needs the driver side front wheel joint replaced
Thor needs the passenger side wheel joint replaced before winter hits
Get the snow plow installed on Thor
Track down and fix the electrical gremlin in the plow controls
Get the backhoe back up and running — it's currently down with a spool valve issue in the controls causing trouble with the left to right swing
All of that has to happen outside, so it's taking priority while I've still got decent weather to work in.
The upside for you all: once I'm off the outdoor projects, my attention is going right back into the site. I've got some updates and improvements I've been wanting to get to, and winter is exactly the stretch of time I need to knock them out. So while the outside work winds down, expect to see more happening here on Mopar1973Man.Com.
As always, thanks for sticking around and being part of the community. More to come soon.
— Mopar1973Man
Recommended Comments
