P0572 Brake Switch Input #1 Signal Missing
(0 reviews)
DTC P0572: BRAKE SWITCH INPUT #1 SIGNAL MISSING
Monitor & Set Conditions
Brake switch input No. 1 signal is monitored with ignition on engine off, and with engine running. DTC may set if Engine Control Module (ECM) sees brake switch OFF and PCM sees brake switch ON for 3 seconds. Condition must be met 10 times for DTC to set.
Possible Causes
  • Wire From Brake Switch To ECM Missing
Testing
Repair open brake switch input wire or replace brake switch.
User Feedback
There are no reviews to display.
