Welcome To Mopar1973Man.Com LLC
We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features.  Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
DTC P1691: FUEL INJECTOR PUMP CONTROLLER CALIBRATION
Monitor & Set Conditions
Fuel injection pump controller calibration is monitored with ignition on engine off and with engine running and no CAN BUS errors reported. DTC may be set when PCM fuel injector pump controller and ECM RPM are mismatched or fuel commanded does not equal amount fueled.
Possible Causes
  • Fuel Injection Pump Failure
  • DTC Returns
Testing
1. Turn ignition on with engine off. Using DRBIII(R) scan tool, check for DTCs. If DTC P1691 does not exist, go to next step. If DTC P1691 exists, replace fuel injection pump. See appropriate REMOVAL, OVERHAUL & INSTALLATION article.
2. Using scan tool, clear DTCs. Start engine and allow engine to idle for one minute. Using scan tool, check for DTCs. If DTC P1691 does not exist, test is complete. If DTC P1691 exists, replace fuel injection pump. See appropriate REMOVAL, OVERHAUL & INSTALLATION article.
User Feedback
There are no reviews to display.
