P0234 Turbo Boost Limit Exceeded
(0 reviews)
P0234 TURBO BOOST LIMIT EXCEEDED
When Monitored and Set Condition:
When Monitored: While running.
Set Condition: The intake air pressure is above a calibrated value for a calibrated amount of time.
POSSIBLE CAUSES
  • OTHER DTC'S
  • WASTEGATE STUCK
DIAGNOSTIC PROCEDURE
NOTE: Refer to VERIFICATION TESTS for appropriate verification test procedures.
  1. Turn the ignition on. With the DRBIII®, read the Engine DTC's. Do you have additional Boost Pressure related faults?
    Yes --> Repair other boost related DTC's first.
    No --> Go To 2
  2. Turn the ignition on. With the DRBIII®, go to the Freeze Frame screen record all data. With the DRBIII®, read DTCs. Operate the vehicle in the Freeze Frame parameters. Did the DTC P-0234 return?
    Yes --> Replace the Wastegate.
    No --> Test Complete.
User Feedback
There are no reviews to display.
