P0335 CRANKSHAFT POSITION (CKP) LOST
When Monitored and Set Condition:
When Monitored: While the engine is running.
Set Condition: The ECM no longer detects a signal from the Crankshaft Position Sensor.
POSSIBLE CAUSES
- OTHER DTCS
- P0337 PRESENT
- CKP SENSOR
- VISUAL DAMAGE
- (G17) SIGNAL CIRCUIT OPEN
- (K6) 5-VOLT SUPPLY CIRCUIT OPEN
- (K167) RETURN CIRCUIT OPEN
- (G17) SIGNAL CIRCUIT SHORTED TO (K167) RETURN CIRCUIT
- (K6) 5-VOLT SUPPLY CIRCUIT SHORTED TO (K167) RETURN CIRCUIT
- (G17) SIGNAL CIRCUIT SHORTED TO (K6) 5-VOLT SUPPLY CIRCUIT
- (G17) SIGNAL CIRCUIT SHORTED TO GROUND
- (K6) 5-VOLT SUPPLY CIRCUIT SHORTED TO BATTERY NEGATIVE
- INTERMITTENT CONDITION
- ECM
DIAGNOSTIC PROCEDURE
With the DRBIII®, read DTCs. Is DTC P2146 and/or P2149 present?
Yes --> Repair other DTCs. Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL).
No --> Go To 2 -
With the DRBIII®, read DTCs. Is P0337 present?
Yes --> Repair P0337 first. Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL).
No --> Go To 3 -
Visually inspect the sensor, engine belt, sensor connector, and the ECM connector. Is there any damage?
Yes --> Repair or replace the sensor, engine belt, harness, or the ECM Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL).
No --> Go To 4 -
Disconnect the CKP sensor harness connector. Check connectors - Clean/repair as necessary. Measure the resistance between the (K6) 5-volt supply circuit and the (G17) signal circuit of the sensor harness connector. Is the resistance between 900 and 1100 ohms?
Yes --> Go To 5
No --> Replace the CKP sensor. Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). -
Disconnect the ECM harness connectors. Disconnect the CKP sensor harness connector. Check connectors - Clean/repair as necessary. Measure the resistance of the (G17) signal circuit between the ECM harness connector and the CKP sensor harness connector. Is the resistance less than 10 ohms?
Yes --> Go To 6
No --> Repair the open (G17) signal circuit. Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). -
Measure the resistance of the (K6) 5-volt supply circuit between the ECM harness connector and the CKP sensor harness connector. Is the resistance less than 10 ohms?
Yes --> Go To 7
No --> Repair the open (K6) 5-volt supply circuit. Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). -
Measure the resistance of the (K167) return circuit between the ECM harness connector and the CKP sensor harness connector. Is the resistance less than 10 ohms?
Yes --> Go To 8
No --> Repair the open (K167) return circuit. Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). -
Measure the resistance between the (G17) signal circuit and the (K167) return circuit in the sensor connector. Is the resistance greater than 100k Ohms?
Yes --> Go To 9
No --> Repair the short circuit or replace the engine harness. Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). -
Measure the resistance between the (K6) 5-volt supply circuit and the (K167) return circuit in the sensor connector. Is the resistance greater than 100k Ohms?
Yes --> Go To 10
Measure the resistance between the (G17) signal circuit and ground. Is the resistance greater than 100k Ohms?
Yes --> Go To 11
Measure the resistance between the (K6) 5-volt supply circuit and ground. Is the resistance greater than 100k Ohms?
Yes --> Go To 12
Measure the resistance between the (G17) signal circuit and the (K6) 5-volt supply circuit in the sensor connector. Is the resistance greater than 100k Ohms?
Yes --> Go To 13
Reconnect the ECM harness connectors. Ignition on, engine not running. With the DRBIII®, erase DTCs. Connect a jumper wire between the sensor supply circuit and the sensor return circuit in the sensor harness connector. Did DTC P0337 set?
Yes --> Refer to the SYMPTOM: INTERMITTENT CONDITION Symptom (Diagnostic Procedure). Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL).
No --> Replace the ECM. Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL).
There are no reviews to display.
