Electrical
Everything pertaining to electrical and computer systems. This also includes charging and starting systems.
3 Cummins articles in this category
ScanGauge II Now here is a invaluable tool for your Dodge product. This works on all OBDII compliant vehicles. Not only does it scan for on board error codes, display and clear them for you. But its got a full trip computer. But this one can be calibrated for your truck. The trip computer is extremely accurate! It's even more accurate than the overhead computer in a Dodge! Then as shown in the picture above you can program the gauges to display
- 0 comments
- 4,593 views
Feed Circuit Test - Voltage Drop Test The starter feed circuit test (voltage drop method) will determine if there is excessive resistance in high-amperage feed circuit. For complete starter wiring circuit diagrams, refer 8, Wiring Diagrams. When performing these tests, it is important to remember that voltage drop is giving an indication of resistance between two points at which voltmeter Example: When testing resistance of battery positive cable, touch voltmeter
- 0 comments
- 14,247 views
Voltage Regulator Mod The voltage regulator on the 92-93 trucks is an internal unit inside the control module. If this goes out, you can mount an external voltage regulator like the earlier first gens used. A bad crankshaft position sensor will also cause your voltage regulator to not charge the altenator. You can also get by this by doing the following: The two terminals on the alternator for the regulator are interchangable. The alternator is a d
- 0 comments
- 15,021 views
