Looking for torque specs for front case to block bolts useing cummins gasket? And also front cover to case bolts useing gray right stuff? Thanks
  • Replies 1
  • Views 1.3k
out of the 2001 FSMgear housing to block 24 N·m (18 ft. lbs.) torque.the front cover is 24 N·m (18 ft. lbs.) torque.and they officially want you to use Mopart Silicone Rubber Adhesive Sealantgood luck
; ipsSettings['maxImageDimensions'] = { width: 1600, height: 1600 }; const ipsJsFileMap = {"communitymap":{"front_markers":"https:\/\/mopar1973man.com\/storage\/theme\/javascript_communitymap\/front_front_markers.js","front_showmap":"https:\/\/mopar1973man.com\/storage\/theme\/javascript_communitymap\/front_front_showmap.js"}};
