Electrical problems
I am putting my 1997 Dodge 3500 Cummins back together after a wreck. I do not have ignition feed to the alt. and the tack does not work and no ground to the a/c compressor relay. Any ideas?
  • Replies 1
  • Views 2.1k
The PCM gives the ground signal to the A/C compressor relay, as well as drive the tach.
On the alternator, the PCM also drives this, but may also be caused by a faulty automatic shut-down relay in the PDC.
